nejde se přihlásit do adminu
07. bře 2019 12:20 #139347
Odpověď od Martin Koumal
Dívám se, že log nejde přečíst... posílám tedy takto:
[Thu Mar 07 02:19:09.245242 2019] [ssl:warn] [pid 2368360:tid 140556542011200] AH01909: www.kzza.sk:443:0 server certificate does NOT include an ID which matches the server name
[Thu Mar 07 07:41:28.262714 2019] [lsapi:notice] [pid 2085177:tid 140555208038144] [client 95.82.129.212:56048] [host kzza.sk] Backend log: PHP Warning: escapeshellcmd() has been disabled for security reasons in /home/krestansk/domains/kzza.sk/public_html/libraries/vendor/phpmailer/phpmailer/class.phpmailer.php on line 1444\n
[Thu Mar 07 07:41:28.482858 2019] [lsapi:notice] [pid 2085177:tid 140555208038144] [client 95.82.129.212:56048] [host kzza.sk] Backend log: PHP Warning: escapeshellcmd() has been disabled for security reasons in /home/krestansk/domains/kzza.sk/public_html/libraries/vendor/phpmailer/phpmailer/class.phpmailer.php on line 1444\n
[Thu Mar 07 07:41:30.686199 2019] [lsapi:error] [pid 2084876:tid 140555312936704] [client 95.82.129.212:56053] [host kzza.sk] Backend fatal error: PHP Fatal error: Class 'JToolbarHelper' not found in /home/krestansk/domains/kzza.sk/public_html/administrator/components/com_cpanel/views/cpanel/view.html.php on line 36\n, referer: kzza.sk/administrator/
[Thu Mar 07 09:20:08.939086 2019] [ssl:warn] [pid 2368360:tid 140556542011200] AH01909: www.kzza.sk:443:0 server certificate does NOT include an ID which matches the server name
[Thu Mar 07 09:46:09.548449 2019] [ssl:warn] [pid 2368360:tid 140556542011200] AH01909: www.kzza.sk:443:0 server certificate does NOT include an ID which matches the server name
[Thu Mar 07 12:00:56.715268 2019] [:error] [pid 2261751:tid 140555281467136] [client 52.203.142.240] ModSecurity: Access denied with code 403 (phase 2). Matched phrase ".ini/" at TX:extension. [file "/usr/local/cwaf/rules/11_HTTP_HTTP.conf"] [line "27"] [id "210730"] [rev "3"] [msg "COMODO WAF: URL file extension is restricted by policy||kzza.sk|F|2"] [data ".ini"] [severity "CRITICAL"] [tag "CWAF"] [tag "HTTP"] [hostname "kzza.sk"] [uri "/language/en-GB/en-GB.ini"] [unique_id "XID56Dmg8risfYDFc-PcewAAAQw"]
07. bře 2019 12:21 #139348
mimochodem, pokud by se někomu chtělo zjistit problém a opravit ho, budu rád - samozřejmě za peníze
07. bře 2019 12:52 #139350
Odpověď od Pavel [byPV]
No tak to skutečně vypadá na nepovedenou aktualizaci Joomla!, kdy se část systému aktualizovala a část ne. Asi netušíte jaká verze tam byla původně a jakou tam máte nyní (nebo spíše jste chtěli mít), že?
Na netu je několik případů se stejným problémem při aktualizaci z 3.8.x na 3.9.0, ale nějak nevidím, že někdo napsal jak k tomu došlo a oprava je tedy asi leda ručně. Zkusím poradit poslepu podle toho co obvykle píší lidé...
Podívejte se, zda-li máte v systému soubor /administrator/includes/toolbar.php .
Pokud ano, tak v souboru /administrator/index.php najděte řádek
a hned za něj vložte následující kód
Pokud ne (soubor /administrator/includes/toolbar.php tam nemáte), tak na stejné místo vložte toto:
Pokud se po úpravě podaří dostat do administrace, tak ihned přejděte do Komponenty -> aktualizace Joomla! a klikněte na Zkontrolovat aktualizace a pak ji nechte znovu aktualizovat tlačítkem níže (počkejte až to komplet doběhne!!!!). Pokud hlásí, že je aktuální, tak dejte přeinstalovat soubory jádra (je tam na to také tlačítko).
Pokud je cokoli jinak (chybí soubory či řádky co jsem psal, tak napište kde co chybí)...
require_once JPATH_BASE . '/includes/subtoolbar.php';
if(!class_exists('JToolbarHelper')) {
require_once JPATH_ADMINISTRATOR . '/includes/toolbar.php';
JLoader::registerAlias('JToolbarHelper', '\\Joomla\\CMS\\Toolbar\\ToolbarHelper', '5.0');
07. bře 2019 14:33 #139359
ten řádek jsem v index.php nenašel... jen
if (!defined('_JDEFINES'))
define('JPATH_BASE', __DIR__);
require_once JPATH_BASE . '/includes/defines.php';
require_once JPATH_BASE . '/includes/framework.php';
a administrator/includes/toolbar.php v souborech není.
07. bře 2019 16:15 #139367
Já bych to nehrotil.
Jestli máte přístup na FTP. Nahrát instalační balíček Joomly + Kickstart.php, rozbalit - neinstalovat, smazat složku v FTP installation, přihlásit se, opravit v administraci databázi. Hotovo.
Ideálně před těmito kroky zálohovat alespoň nefunkční web.
