Problém s instalaci yoo zoo
- Majky
21. srp 2014 00:01 - 21. srp 2014 00:02 #117523
od Majky
Problém s instalaci yoo zoo od Majky
Dobrý den. Poprosím Vás o radu. Mám Joomla 2.5.24. Měl jsem tam zoo které mi nešlo aktualizovat. Tak jsem ho kompletně vymazal i z databaze. Teď když ho chcu znova nainstalovat tak mi to při instalaci napiše tohle:
JInstaller: :Instalace: Chyba SQL DB funkce selhala, číslo chyby 1283
Column 'name' cannot be part of FULLTEXT index SQL=--
CREATE TABLE IF NOT EXISTS wisucu322_zoo_item ( `id` int(11) NOT NULL auto_increment, `application_id` int(11) NOT NULL, `type` varchar(255) NOT NULL, `name` varchar(255) NOT NULL, `alias` varchar(255) NOT NULL, `created` datetime NOT NULL, `modified` datetime NOT NULL, `modified_by` int(11) NOT NULL, `publish_up` datetime NOT NULL, `publish_down` datetime NOT NULL, `priority` int(11) NOT NULL, `hits` int(11) NOT NULL, `state` tinyint(3) NOT NULL, `access` int(11) NOT NULL, `created_by` int(11) NOT NULL, `created_by_alias` varchar(255) NOT NULL, `searchable` int(11) NOT NULL, `elements` longtext NOT NULL, `params` longtext NOT NULL, PRIMARY KEY (`id`), UNIQUE KEY `ALIAS_INDEX` (`alias`), KEY `PUBLISH_INDEX` (`publish_up`,`publish_down`), KEY `STATE_INDEX` (`state`), KEY `ACCESS_INDEX` (`access`), KEY `CREATED_BY_INDEX` (`created_by`), KEY `NAME_INDEX` (`name`), KEY `APPLICATIONID_INDEX` (`application_id`), KEY `TYPE_INDEX` (`type`), KEY `MULTI_INDEX` (`application_id`,`access`,`state`,`publish_up`,`publish_down`), KEY `MULTI_INDEX2` (`id`,`access`,`state`,`publish_up`,`publish_down`), KEY `ID_APPLICATION_INDEX` (`id`,`application_id`), FULLTEXT KEY `SEARCH_FULLTEXT` (`name`) ) ENGINE=MyISAM;
SQL =
CREATE TABLE IF NOT EXISTS #__zoo_item (
PRIMARY KEY (`id`),
) ENGINE=MyISAM;
Instalace komponenty: SQL chyba souboru DB funkce selhala, číslo chyby 1283
SQL =
PRIMARY KEY (`id`),
) ENGINE=MyISAM;
Víte mi poradit co to je? Děkuji
SQL =
PRIMARY KEY (`id`),
) ENGINE=MyISAM;
SQL =
PRIMARY KEY (`id`),
) ENGINE=MyISAM;
21. srp 2014 01:57 #117524
Odpověď od Cony v tématu Problém s instalaci yoo zoo
Zkontrolujte si nastavení porovnávání databáze, máte nastaveno na utf8_general_ci ?
- Majky
21. srp 2014 15:45 #117528
od Majky
Odpověď od Majky v tématu Problém s instalaci yoo zoo
Jo mám to tak.
- Majky
22. srp 2014 16:30 - 22. srp 2014 16:36 #117533
od Majky
Odpověď od Majky v tématu Problém s instalaci yoo zoo 2
Dobrý den. Pokud instaluji yoo zoo verze 3.1.6 tak se my vše nahraje do databaze jak má ale do ftp absolutne nic. Po instalaci mi to napiše:
- Instalace komponenty: DB funkce jsou bez chyb
- Při instalaci komponenty došlo k chybě.
Víte mi poradit? Děkuji
22. srp 2014 16:50 #117534
Odpověď od Bong v tématu Problém s instalaci yoo zoo 2
Kde hostujete? Nemáte třeba problém s vlastnictvím složek a souborů? Jiná rozšíření nainstalovat jdou?
Když jste staré ZOO mazal, tak proč ručně? Proč jste jej neodinstaloval?
- Majky
22. srp 2014 17:12 #117535
od Majky
Odinstaloval jsem ho ale neodinstalovalo se mi vše. Tak sem vše domazal ručně. A teď mi nejede nainstalovat. Jo jiné věci instaluje v pohodě.
Vygenerováno za 0.071 sekund
