Phoca Download - problém s uploadom cez frontend
- ferino
21. pro 2022 22:15 - 21. pro 2022 22:17 #147522
od ferino
Ahojte,
nerobím bežne Joomlu pod Windows Serverom - IIS, ale v tomto prípade som musel...
Inštalácia sa mi podarila bez nejakých väčších problémov, aj vyzerá že to normálne funguje, problém mám akurát s uploadom súboru cez frontend
Jednoducho to nejde, popis chýb po nastavení debug módu pripájam nižšie..
Pritom cez backend to uploaduje jedna radosť...
Je rozdiel medzi jedným a druhým uploadom? Treba niečo nastaviť v PHP?
Joomla v4.2.6
Phoca Download v4.0.4
PHP v7.4.13
mySQL 8.0.31
Web Server: Microsoft-IIS/10.0
Joomla v4.2.6
PHP v7.4.13
mySQL 8.0.31
0 Call to undefined method Joomla\Database\Mysqli\MysqliDriver::getError()
Call stack
# Function Location
1 () JROOT\components\com_phocadownload\models\user.php:488
2 PhocaDownloadModelUser->_save() JROOT\components\com_phocadownload\models\user.php:375
3 PhocaDownloadModelUser->singleFileUpload() JROOT\components\com_phocadownload\views\user\view.html.php:207
4 PhocaDownloadViewUser->display() JROOT\libraries\src\MVC\Controller\BaseController.php:639
5 Joomla\CMS\MVC\Controller\BaseController->display() JROOT\components\com_phocadownload\controller.php:37
6 PhocaDownloadController->display() JROOT\libraries\src\MVC\Controller\BaseController.php:672
7 Joomla\CMS\MVC\Controller\BaseController->execute() JROOT\components\com_phocadownload\phocadownload.php:59
8 require_once() JROOT\libraries\src\Dispatcher\LegacyComponentDispatcher.php:71
9 Joomla\CMS\Dispatcher\LegacyComponentDispatcher::Joomla\CMS\Dispatcher\{closure}() JROOT\libraries\src\Dispatcher\LegacyComponentDispatcher.php:73
10 Joomla\CMS\Dispatcher\LegacyComponentDispatcher->dispatch() JROOT\libraries\src\Component\ComponentHelper.php:355
11 Joomla\CMS\Component\ComponentHelper::renderComponent() JROOT\libraries\src\Application\SiteApplication.php:200
12 Joomla\CMS\Application\SiteApplication->dispatch() JROOT\libraries\src\Application\SiteApplication.php:241
13 Joomla\CMS\Application\SiteApplication->doExecute() JROOT\libraries\src\Application\CMSApplication.php:294
14 Joomla\CMS\Application\CMSApplication->execute() JROOT\includes\app.php:61
15 require_once() JROOT\index.php:32
21. pro 2022 22:26 #147523
Odpověď od H13 v tématu Phoca Download - problém s uploadom cez frontend
Ahoj, nejsem si jistej, ale tohle tuším už bylo OK v poslední Beta verzi, zkus stáhnout a nainstalovat poslední Beta a dej vědět:
github.com/PhocaCz/PhocaDownload/release...load_v4.0.5Beta4.zip
Poděkovali: ferino
- ferino
21. pro 2022 22:29 #147524
od ferino
Odpověď od ferino v tématu Phoca Download - problém s uploadom cez frontend
Vďaka, skúsim zajtra, lebo to mám v práci na intranete...
- ferino
22. pro 2022 07:51 #147528
od ferino
Veľká vďaka - v tejto betaverzii to funguje...
Urobím za to slovenský preklad a pošlem
22. pro 2022 12:04 #147534
Odpověď od Bong v tématu Phoca Download - problém s uploadom cez frontend
Slovenština pro Phoca Download J4 je ve stádiu rozpracovanosti. Ale měla by jít použít i slovenština pro J3.
A pokud použijete i plugin pro překlady Installer - Install from Bongovo.cz, tak se pak nová slovenština pro Phoca Download po zveřejnění nabídne k instalaci.
- ferino
22. pro 2022 13:05 #147536
od ferino
Plugin "Install from Bongovo.cz" nainštalovaný mám, ale pri Phoca Download sa mi ponúka iba čeština...
22. pro 2022 13:54 #147538
Slovenština bude co nevidět. Nejspíš už zítra. Pak se bude nabízet také.
Poděkovali: ferino
23. pro 2022 06:40 - 23. pro 2022 06:55 #147546
Poděkovali: ferino
- ferino
23. pro 2022 08:23 - 23. pro 2022 08:28 #147548
od ferino
Už to vidím v zozname, akurát ukazuje mi tam Language cs-CZ
Phoca Download (slovenčina)
Slovenčina pro komponent, moduly a pluginy Phoca Download - administrátorske a užívateľské rozhranie.cs-CZ4.0.5Beta64.0.4Update
Ale inak to ide, vďaka, skontrolujem to a dám vedieť...
- ferino
27. pro 2022 16:00 #147574
od ferino
Jednu drobnosť som našiel
"Kategória: 2 / Súbory: 9" - malo by byť "Kategórie: 2 / Súbory: 9"
Podobne pri tlačidle ktoré vracia na zoznam kategórii "< Kategória" má byť "< Kategórie"
27. pro 2022 16:33 #147577
Upraveno, aktualizujte a vyzkoušejte.
Poděkovali: ferino
- ferino
27. pro 2022 20:34 #147589
od ferino
Super, vďaka.
Vygenerováno za 0.096 sekund
