Zasilkovna nefunguje
01. čvc 2020 11:57 #142656
Dobry den nekdo kdo pomuze ze Zasilkovne . Instaloval jsem novy modul a uz se nezobrazuje , .Pise tohle , Snazil jsem se to opravit a neslo.
Notice: Only variables should be passed by reference in /data/web/virtuals/10175/virtual/www/administrator/components/com_virtuemart/views/zasilkovna/view.html.php on line 63 Notice: Only variables should be passed by reference in /data/web/virtuals/10175/virtual/www/administrator/components/com_virtuemart/views/zasilkovna/view.html.php on line 64 Notice: Only variables should be passed by reference in /data/web/virtuals/10175/virtual/www/administrator/components/com_virtuemart/views/zasilkovna/view.html.php on line 206 Notice: Only variables should be passed by reference in /data/web/virtuals/10175/virtual/www/administrator/components/com_virtuemart/views/zasilkovna/view.html.php on line 208 Notice: Only variables should be passed by reference in /data/web/virtuals/10175/virtual/www/administrator/components/com_virtuemart/views/zasilkovna/view.html.php on line 217
Warning: filemtime(): stat failed for /data/web/virtuals/10175/virtual/www/administrator/components/com_virtuemart/views/zasilkovna/tmpl/../../../media/com_zasilkovna/media/css/admin.css in /data/web/virtuals/10175/virtual/www/administrator/components/com_virtuemart/views/zasilkovna/tmpl/default.php on line 25 Warning: filemtime(): stat failed for /data/web/virtuals/10175/virtual/www/administrator/components/com_virtuemart/views/zasilkovna/tmpl/../../../media/com_zasilkovna/media/js/repeater.js in /data/web/virtuals/10175/virtual/www/administrator/components/com_virtuemart/views/zasilkovna/tmpl/default.php on line 26 Warning: filemtime(): stat failed for /data/web/virtuals/10175/virtual/www/administrator/components/com_virtuemart/views/zasilkovna/tmpl/../../../media/com_zasilkovna/media/js/admin.js in /data/web/virtuals/10175/virtual/www/administrator/components/com_virtuemart/views/zasilkovna/tmpl/default.php on line 27
01. čvc 2020 13:31 #142657
Tato informace pro nalezení chyby podle mého soudu nestačí.
Chtělo by to živou URL a prozkoumat přímo v košíku.
01. čvc 2020 16:26 #142658
A hlavně, co to bylo za modul? Podle výpisu chyb to bude nějaké rozšíření, které zasahuje přímo do virtumeart (přidává view zasilkovna). To není úplně šťastný způsob, aktualizací VM může dojít ke změnám a znefunkčnění...
Co Vám k tomu řekne autor toho rozšíření pro Zásilkovnu?
01. čvc 2020 20:48 #142659
to Cony:
To je standardní verze pluginu od Zásilkovny, který opravdu přidává při instalaci modely a view přímo do administrace VirtueMartu.
Bohužel tato verze (jak je u Zásoilkovny obvyklé - u verze pro VM2 jsme taky museli hackovat, protože plugin neukládal do DB zásadní informace o dopravě pro administrátory a neuměl v košíku zobrazit dvě instance dopravy pod sebou) je chybová.
Většinou je třeba řešit s podporou, ale je taky třeba počítat s možnými problémy již při vývoji:
- použití OPC košíku
- instalace na subdoménu nebo nestandardní hosting
- nestandardní nastavení, které odporuje programovému kódu
- nekompatibilita s verzí VM
Jejich vývojáři ale mají dlouhé dodací doby (klidně i půl roku nebo taky vůbec).
Pak se tady objevuje dotaz tohoto typu, který na první pohled nesouvisí se Zásilkovnou, ale s hostingem.
Odpověď a řešení odpovídá kvalitě dotazu.
Poděkovali: Cony
01. čvc 2020 20:58 #142660
Odpověď od slavei
Děkuji za odpověď. Předtím to fungovalo taky psalo chyby. Řešil jsem z podpora Zasilkovnu 6 měsíců. Furt sliboval ze napíše kde je problém a nic . Teď vydali novy modul . Tak jsem to nainstaloval .
Je to web www.rosaimpex.cz
01. čvc 2020 21:14 - 01. čvc 2020 21:16 #142661
1. máte tam JS chybu v aplikaci PickUpAtPlace od pana Vakeše (ReferenceError: Can't find variable: PickUpAtPlace_byPV)
2. Používáte Zásilkovnu pro VM, přitom ale máte košík od VP One Page od pana Vakeše
3. Máte instalaci výdejních míst od pana Vakeše
Suma sumárum tenhle problém nevyřešíte čistou administrací a instalací (bylo bláhové si myslet, že si nainstalujete novou verzi zásilkovny od Zásilkovny a přitom používáte ajaxový košík a výdejny pro PickUpAtPlace a ono to bude fungovat) ale komunikací s panem Vakešem a Zásilkovnou.
A zde na fóru už vůbec ne.
Nebo si objednejte programátora.
