Jak na strukturovaná data
14. lis 2018 12:12 - 14. lis 2018 12:12 #137685
to právě není, že by se vždy vyplnilo @ID samo
kód
<article itemscope itemtype="https://schema.org/Article" itemid=""> <meta itemprop="headline" content="<?php echo $this->item->title; ?>"/> <meta itemprop="name" content="<?php echo $this->item->title; ?>"/> <meta itemprop="mainEntityOfPage" content="<?php echo $this->item->absoluteURL; ?>"/> <meta itemprop="inLanguage" content="<?php echo ($this->item->language === '*') ? JFactory::getConfig()->get('language') : $this->item->language; ?>" /> <meta itemprop="image" content="<?php echo JURI::base().$this->item->image; ?>"/> <span meta itemscope itemtype="https://schema.org/Person" itemprop="author" content="<?php echo $this->item->author->name; ?>"/><meta itemprop="name" content="<?php echo $this->item->author->name; ?>"/></span> <meta itemprop="datePublished" content="<?php echo $this->item->created; ?>"/> <meta itemprop="dateModified" content="<?php echo $this->item->modified; ?>"/> <span meta itemscope itemtype="https://schema.org/Organization" itemprop="publisher" content="Diochi"/><meta itemprop="name" content="Diochi"/></span> </article>
vytvoří položku @id s aktuální URL článku, ale
<article itemscope itemtype="https://schema.org/Article"> <meta itemprop="headline" content="<?php echo $this->item->title; ?>"/> <meta itemprop="name" content="<?php echo $this->item->title; ?>"/> <meta itemprop="mainEntityOfPage" content="<?php echo $this->item->absoluteURL; ?>"/> <meta itemprop="inLanguage" content="<?php echo ($this->item->language === '*') ? JFactory::getConfig()->get('language') : $this->item->language; ?>" /> <meta itemprop="image" content="<?php echo JURI::base().$this->item->image; ?>"/> <span meta itemscope itemtype="https://schema.org/Person" itemprop="author" content="<?php echo $this->item->author->name; ?>"/><meta itemprop="name" content="<?php echo $this->item->author->name; ?>"/></span> <meta itemprop="datePublished" content="<?php echo $this->item->created; ?>"/> <meta itemprop="dateModified" content="<?php echo $this->item->modified; ?>"/> <span meta itemscope itemtype="https://schema.org/Organization" itemprop="publisher" content="Diochi"/><meta itemprop="name" content="Diochi"/></span> </article>
nevytvoří položku @ID (rozdíl je jen v prvním řádku)
Něco k tomu je popsáno zde
14. lis 2018 12:20 #137686
Joomlaportal má nasazené Rich snippets jen na detail článku:
search.google.com/structured-data/testin...vky-a-sdileli-je-dal
@Typ == Article se zde vypní samo, pokud doplníte:
<article id="k2article" itemscope itemtype="http://schema.org/Article">
Důležité není to id="k2article", ale itemscope itemtype=" schema.org/Article "
@id == www.joomlaportal.cz/jak-zacit/k2article se zde vyplní samo:
protože se vyplní URL adresa kde jsem + ID z tagu
Tady si myslím že má autor chybu.
Správná implementace má být:
<article itemscope itemtype="http://schema.org/Article">
Protože v elementu Article na Schema @id není
14. lis 2018 12:23 #137687
Tady je ukázka jak jsem implementoval já:
search.google.com/structured-data/testin...-na-biostyl-ecoworld
14. lis 2018 12:25 - 14. lis 2018 12:26 #137688
Id se vyplní samo, pokud ho v tom tagu máte.
Je to opravdu chyba Google tester tools.
Ale je to taky chyba implementátora, tam vůbec id nemá co dělat.
Má si vytvořit nový obalový tag pro tag article, pokud to id potřebuje ke stylování.
14. lis 2018 12:29 #137689
Máte špatně
správně
<meta itemscope itemprop="mainEntityOfPage" itemtype=" schema.org/WebPage " itemid="item->absoluteURL; ?>"/>
14. lis 2018 12:32 #137690
> <span meta itemscope itemtype=" schema.org/Organization " itemprop="publisher" content="Diochi"/>
Myslím že logo je povinná položka?
