Joomla a MSSQL problém
- McVitas
18. říj 2017 21:42 - 18. říj 2017 21:44 #132646
od McVitas
Joomla a MSSQL problém od McVitas
Zdravim, podařilo se to někomu zprovoznit? Mám IIS, PHP 7, MS SQL Express 2016.
Tento example script mi funguje
Ale Joomla při instalaci hlásí
$serverName = "localhost\sqlexpress"; //serverName\instanceName
// Since UID and PWD are not specified in the $connectionInfo array,
// The connection will be attempted using Windows Authentication.
$connectionInfo = array( "Database"=>"testdb");
$conn = sqlsrv_connect( $serverName, $connectionInfo);
if( $conn ) {
echo "Connection established.<br />";
}else{
echo "Connection could not be established.<br />";
die( print_r( sqlsrv_errors(), true));
Could not connect to the database. Connector returned number: Database sqlsrv_connect failed, Array ( [0] => Array ( [0] => 08001 [SQLSTATE] => 08001 [1] => 2 [code] => 2 [2] => [Microsoft][ODBC Driver 13 for SQL Server]Named Pipes Provider: Could not open a connection to SQL Server [2]. [message] => [Microsoft][ODBC Driver 13 for SQL Server]Named Pipes Provider: Could not open a connection to SQL Server [2]. ) [1] => Array ( [0] => HYT00 [SQLSTATE] => HYT00 [1] => 0 [code] => 0 [2] => [Microsoft][ODBC Driver 13 for SQL Server]Login timeout expired [message] => [Microsoft][ODBC Driver 13 for SQL Server]Login timeout expired ) [2] => Array ( [0] => 08001 [SQLSTATE] => 08001 [1] => 2 [code] => 2 [2] => [Microsoft][ODBC Driver 13 for SQL Server]A network-related or instance-specific error has occurred while establishing a connection to SQL Server. Server is not found or not accessible. Check if instance name is correct and if SQL Server is configured to allow remote connections. For more information see SQL Server Books Online. [message] => [Microsoft][ODBC Driver 13 for SQL Server]A network-related or instance-specific error has occurred while establishing a connection to SQL Server. Server is not found or not accessible. Check if instance name is correct and if SQL Server is configured to allow remote connections. For more information see SQL Server Books Online. ) )
- HonzaG
21. říj 2017 20:12 #132687
od HonzaG
Odpověď od HonzaG v tématu Joomla a MSSQL problém
a to ti to hlásí při instalaci nebo po instalaci?
Podle zkušeností s MS SQL bych začal kontrolou práv na DB a tabulky pro daného uživatele....
Víc Ti takhle neporadím, když nenapíšeš, co tomu objevení chyby předcházelo.
HonzaG
HonzaG
23. říj 2017 00:56 #132694
Odpověď od Cony v tématu Joomla a MSSQL problém
Joomla 4 již MS SQL nebude podporovat. Pokud si nechcete zadělat na potíže do budoucna, MS SQL bych opustil.
Vygenerováno za 0.051 sekund
