Důležité Problém při migraci
21. čvn 2012 09:33 #94876
Problém při migraci od Sparta.net
Dobrý den, mám problém při migraci pomocí komponenty "jUpgrade", každá migrace se mi zasekne v bodě "Upgrading progress...".
Debug mi píše:
[checks]
1
[cleanup]
1
[decompress]
1
[install_config]
Fatal error: Class 'JModelLegacy' not found in /data5/gvncz/html/houmrovo/dramka/dramka/installation/models/configuration.php on line 20
[install_db]
Fatal error: Class 'JModelLegacy' not found in /data5/gvncz/html/houmrovo/dramka/dramka/installation/models/database.php on line 20
[undefined] [undefined]
Warning: require_once() [function.require-once]: Unable to access /data5/gvncz/html/houmrovo/dramka/dramka/configuration.php in /data5/gvncz/html/houmrovo/dramka/administrator/components/com_jupgrade/includes/jupgrade.class.php on line 88
Warning: require_once(/data5/gvncz/html/houmrovo/dramka/dramka/configuration.php) [function.require-once]: failed to open stream: No such file or directory in /data5/gvncz/html/houmrovo/dramka/administrator/components/com_jupgrade/includes/jupgrade.class.php on line 88
Fatal error: require_once() [function.require]: Failed opening required '/data5/gvncz/html/houmrovo/dramka/dramka/configuration.php' (include_path='.') in /data5/gvncz/html/houmrovo/dramka/administrator/components/com_jupgrade/includes/jupgrade.class.php on line 88
Nevíte co s tím mám dělat ? :)
21. čvn 2012 10:36 - 21. čvn 2012 10:39 #94882
