phoca cart filter module
01. bře 2024 17:10 #149215
![](https://joomlaportal.cz/media/kunena/avatars/resized/size36/users/avatar2928.png)
Testovat se do dá od verze 5.0.0 Beta33:
github.com/PhocaCz/PhocaCart/releases/do...art_v5.0.0Beta33.zip
Když budeme věřit Joomla core vývojářům, měla by i verze 5 běžet na 4.4 a vyšší.
Poběží to i na joomla 4?
Poděkovali: Ernst
01. bře 2024 21:26 - 01. bře 2024 21:28 #149217
![](https://joomlaportal.cz/media/kunena/avatars/nophoto.png)
tak bohužel ne. při spuštění čehokoliv z phoca v administraci to píše
Došlo k chybě.
0 Interface "Joomla\CMS\Schemaorg\SchemaorgServiceInterface" not found
Call stack
# Function Location
1 () JROOT/administrator/components/com_phocacart/src/Extension/PhocaCartComponent.php:44
2 include_once() JROOT/libraries/loader.php:521
3 JLoader::loadByPsr() JROOT/administrator/components/com_phocacart/services/provider.php:44
4 Joomla\DI\ServiceProviderInterface@anonymous/www/doc/www.aquion.cz/www/administrator/components/com_phocacart/services/provider.php:27$75->{closure}() JROOT/libraries/vendor/joomla/di/src/ContainerResource.php:182
5 Joomla\DI\ContainerResource->getInstance() JROOT/libraries/vendor/joomla/di/src/Container.php:96
6 Joomla\DI\Container->get() JROOT/libraries/src/Extension/ExtensionManagerTrait.php:177
7 Joomla\CMS\Application\CMSApplication->loadExtension() JROOT/libraries/src/Extension/ExtensionManagerTrait.php:51
8 Joomla\CMS\Application\CMSApplication->bootComponent() JROOT/libraries/src/Component/ComponentHelper.php:361
9 Joomla\CMS\Component\ComponentHelper::renderComponent() JROOT/libraries/src/Application/AdministratorApplication.php:143
10 Joomla\CMS\Application\AdministratorApplication->dispatch() JROOT/libraries/src/Application/AdministratorApplication.php:186
11 Joomla\CMS\Application\AdministratorApplication->doExecute() JROOT/libraries/src/Application/CMSApplication.php:293
12 Joomla\CMS\Application\CMSApplication->execute() JROOT/administrator/includes/app.php:61
13 require_once() JROOT/administrator/index.php:32
Nešlo by s tím prosím něco udělat?
Modul filtru je ok
frontend dává stejnou chybu:
aquion.cz.uvirt135.active24.cz/index.php...ems&id=0&Itemid=1111
Joomlla 4.4.3 , php 8.1.27
Došlo k chybě.
Call stack
# Function Location
Modul filtru je ok
02. bře 2024 03:06 #149219
![](https://joomlaportal.cz/media/kunena/avatars/resized/size36/users/avatar2026.jpg?1653054499)
Phocacart 5 beta 35 by to měla vyřešit
Poděkovali: Ernst
12. bře 2024 18:29 - 12. bře 2024 18:32 #149265
zkusil jsem až teď beta39 a hlásí to chybu:
Instalace: Chyba SQL Duplicate column name 'redirect_product_id'
Instalace rozšíření byla přerušena.
Při instalaci komponenty došlo k chybě.
Dělal jsem to jako upgrade z 4.0.10
12. bře 2024 22:43 #149270
Divný. Nepouštěl jsi už nějaký update dřív? Zkontroluj v phpMyAdmin tabulku phocacart_products, ve verzi 4 by tam sloupec redirect_product_id neměl být.
Poděkovali: Ernst
13. bře 2024 10:13 #149272
ano je to tím, udělal jsem upgrade na beta 33 a tio tenkrát hlásilo chyby, tak jsem to přehrál 4.0.10.
Co mi těď doporučíš?
ručně porovnat a upravit tabulky?
vyexportovat data, smazat a pak naimportovat?
nějaké jiné řešení?
nějaké jiné řešení?
